Paint will not dry
5 Jun 2011
London
I have had a problem overpainting Puraflex 40.
It was recommended to me that Puraflex 40 was a good material to sort out a crack that follows where the stringer of the staircase meets the wall. The Puraflex applied fine but the oil based paint which I painted over with will not dry. I painted about 4 days ago but still not dry. My question is will this paint dry eventually or is there some other problem??
Many thanks in advance for any help...
Just have to wait for it to dry. Oil gloss I guess? That takes and age anyway and can stay sticky for over a week anyway.
You should have used waterbased primer first. Oil based paints over MS polymers can stay tacky for months (seriously months...). All is not lost, just touch in with waterbased primer (over the tacky OB) and then apply the OB paint the next day.
I have painted over 24 month old MS polymers with OB, not realising that they were MS polymers and the OB paint still stayed tacky until I hit them with WB primer/undercoat.
Who recommended that?
You need a low modulus sealant for cracks not high modulus
There are very few low modulus MS Polymers (although Puraflex 25 is one, but AFAIK it is not as readily available). Most low modulus products are silicone based and therefore not suitable for painting. IMO, a low modulus MS polymers is more elastic than any regular caulk that I have previously used and they have the added advantage of not shrinking back (like caulk).
If you are able to recommend a low modulus paintable sealant I would be happy to try it out. Many thanks. Opps
Thanks for the link. Unfortunately most of those sealants are not MS polymers and not very flexible.
The following link from the same site lists low modulus sealants. Although most of them are silicone, and therefore not suitable for the task in hand, three quarters of the way down however there are some low modulus MS polymers which I might try out (and which are relatively cheap).
Have you got that link ? (I'm being lazy)
