Painting a newly plastered wall
21 Sep 2013
Kent
A brick wall was plastered last year. I wish now to paint it with Santex masonary paint. Do I / or can I coat the wall with a stabilising solution before painting it (and would you advise 2 coats of paint - as I need access next door to do this I want to get it right - early answer would be very welcome now that the weather is improving. Many thanks jnscts
15 Nov 2005
Crossgates, Europe
Cook Islands
No.
Apply mist coats (I prefer two) of the masonry paint thinned with water. They will soak into the surface and disappear almost immediately. You will know when you have killed the suction because it will no longer suck the paint off your brush. After that you can apply the unthinned paint. It will look and last better with two coats.
Use a mixing tool in a hand drill because it must be stirred very thoroughly.
21 Sep 2013
Kent
Thanks john - I assume a mist coat is a diluted (watered down coat) and is it 50/50 Are you a
So saying that I will not need to use the paint as a final coat after the watered down coat has dried. Thanks for your rapid response Regards John
Ps I used to be a Fifer many moons ago
15 Nov 2005
Crossgates, Europe
Cook Islands
The mist coats soak in, so when they are dry (very quick) you apply the unthinned finish paint.
Opinions differ about how much water to add for the mist coats. I like it as thin as milk and it is very fast to apply.
When you get started, you will soon see and feel the difference between a bare wall (paint just gets sucked in and all moisture disappears) and one that is ready for finish coats (paint coats the surface)
Emulsion paint indoors is the same method, on absorbent bare plaster or patches of filler.
21 Sep 2013
Kent
Many thanks for your reply - I will try the way you have suggested. I am also pointing some brick work at the moment and reading through the Smiths DIY Manual it suggests a mix of 6 to 1 I tried this the other day and it was far too weak; I tried this with plastering sand and it was a total disaster - any suggestions ( I undestand if you ignore this ? (I did buy the stabilising solution to paint over an original house wall which is a bit crumbly
21 Sep 2013
Kent
I have read through some other recommendations on this web site and they all stress that mist coats are to be applied initially - before a good masonary top coat - last question as this is an outside wall what paint can I use as mist coats ? Looking at replies they even mention emulsion paint (indoor or outdoor ?? )
8 Nov 2007
Suffolk
Just thin enough of the masonary paint you are using for the finished job then cracking on with painting as normal.
