Painting on bare new plaster board
25 Jul 2008
Bristol
Hi. I have drylined internal walls and put up new ceilings to cover up artex. I saw that new board should have a sealer on it to act as a vapour barrier. Unfortunately its not cheap like everything currently. Is this necessary and or is there an alternative. Previously I have just emulsioned straight over the plaster board
Advise appreciated
I hired plasterer to skim artex textures ceiling few months ago, First coat, I applied diluted emulsion with water 10% then another 2 coats of emulsion.
I waited 3 weeks for skim to dry.
Thanks but not relevant to my scenario :)
What's the new ceiling made of?
I have done same with plasterboard ceiling in an office.
Plasterboard. I have previously treated it as plaster, mist coat then emulsion but saw on tutorial it should have a sealer / vapour barrier.
Why? Is it a bathroom?
Who made the tutorial?
Don't put glue on it.
My skimmed ceiling was bathroom, I didn't use any sealer just diluted emulsion but used Dulux bathroom paint which is sufficient.
If you have dot&dabbed or screwed over existing walls, why you need a vapour barrier?
Plasterboard is a really good surface to emulsion straight onto.
Although if I've had a wall that has needed a lot of filler/drywall compound, I have used Zinsser Gardz, or Dulux plaster sealer. I find it gives a good surface to paint on, whilst not reactivating the filler.
It is expensive though!
If you need a vcl it's usual to put polythene behind the pb. Carry on with yr mist coats and then emulsion
