Painting onto hardboard
1 Aug 2011
Bristol
Hello
I have built some shelves in an alcove using battening and 6mm hardboard from B&Q (the pale brown kind with smooth surface top and bottom)
Can I paint white gloss directly onto this, or does it need to be primed all over? I have some mdf primer would that do? And should I just prime the edges or do I need to prime the smooth top and bottom surfaces too?
Big thanks
Tom
hi Tom, you will need to prime it, if you have got mdf primer you might as well use it I would'nt normally recommend it as it's just a marketing ploy any wood primer is fine!.if your glossing best to undercoat aswell as the brown colour will "grin" through if you don't put enough coats on! hope this helps!
also Tom!
tom,
With regard to the mdf primer I would before entire application do a small test area and offer enough time for the primer to both dry and cure, then give it the finger nail test, if in any way the primer is removed please post back.
Dec
