Painting over glossed stone floor..??
11 Sep 2014
London
Hi folks..
I have a concrete floor that I'd like to paint over with a hard wearing floor paint but the floor already has been previously painted with standard oil based gloss paint. The finish is very sound and clean with no peeling or flaking.
Can I just sand it lightly to cut the surface and paint over it with the floor paint or do I need to strip the whole thing back to the concrete which would be a real mess if not impossible to do!?
I'm worried that the presence of an oil based coat of gloss will create a softer membrane between the hard concrete floor and the new stone paint I wish to apply and result in a less durable finish?
Any advice would me greatly appreciated.
Thank you.
As you suggest, removing the existing gloss would be a nightmare task so I think all you can do is sand back as much as possible to remove the sheen from it. This will usually be good enough for most paints to adhere to but if your 'stone paint' is a product that needs to be applied directly to bare stone then you could be in trouble.
What is the product you have chosen?
I think I will be OK as I just read this on painting on stone and concrete surfaces:
"water based paints can be applied to surfaces previously painted in an oil based finish. However, surfaces painted in oil based paint require a minimum of two weeks drying time before water based paint is applied on top. "
http://www.farrow-ball.com/preparing-exterior-masonry/content/fcp-content
That's good news then. Will just sand and cut it before painting and find a water based stone floor paint.
"Painted concrete floors – clean and remove any surface debris, any areas that have peeled or blistered, rub down to achieve a good ‘key."
http://www.farrow-ball.com/interior-floors/content/fcp-content
Cheers.
