Painting Plumbers Mait
17 Feb 2006
The outlet from a toliet goes into the cast iron soil pipe. The joint is made with 'Plumbers Mait' (the non setting sticky stuff in a tub, not the setting stuff in a tube). The old one was filthy, because of course Plumbers Mait attracts all the dust and fluff going. I carved the top layer off and remade the joint.
In order to keep it clean, and just for appearance, I thought about painting it. According to Evostick's website it'll take any sort of emulsion or gloss.
Anybody had any success with this? I'm tempted to use an emulsion, as I figure a water based paint is less likely to react with whatever oil type stuff is in the Plumbers's Mait.
Also the lower bit seemed to have deteriorated. A bit sort of pockmarked, as though it had 'washed away' or something. Does anybody know anything that would dissolve Plumber's Mait? Presumably not water!!
Cheers.
Completely by accident, I discovered that this cleans it:
ae235
