that bathroom paint will help quite a lot we had terrible problems with flaking paint after we fitted a shower. we painted with bathroom paint and leave the small fanlight window permenantly open about 3" with the stay screwed down for security and haven't had any problems for the last year or so.
Thanks for your replies. Think i'll look into replacing the extractor fan, which sounds like it's simply worn out, and then repaint.
So, to be clear as to what i should do - remove the flaking paint back to the plaster, seal the plaster (two coats) and then two coats of emulsion? Would it help if i then sealed the paint (i use diluted evo)?
Failing that it's specialist paint or the plastic sheet which sounds like a good idea.
