Just want to confirm before i wire up, I have a 9943 Keypad which allows for a panic button to be installed off it.
The manual doesn't say, but does say that if your using just the panic loop (ie not the tamper) then the tamper must be linked out, if your not using either, (ie no panic at all) then both the panic loop and tamper loops must be linked out.
Do i wire the panic in as FSL or 4CC? My system is in FSL.
