Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Just spoken to my local building centre who have a product called laybond for Parquet flooring, has anyone used this and is it suitable for my situation? as I am struggling to get any Lecol locally
Found L80 Multibond Gold on our suppliers list (never used it ourselves):
A multi-purpose, acrylic floor-covering adhesive
Available in 15kg, 5 kg, 2.5 kg and 1 kg packaging
L16 Wood Bond
Description
A filled solution of synthetic polymer resins in a blend of solvents. Formulated to trowel consistency.
Uses
For bonding all types of parquet flooring, wood strip and wood block to most common substrates. Water free, very high shear strength & good initial grab.
L17 Wood Block
Description
A bitumen / rubber emulsion of dipping consistency.
Uses
For bonding wood blocks of 12mm thickness and over to most common substrates
Do you think I will be better off using one of the above ?
