I know there are some very knowledgeable floorers on here, so ...
I'm wanting to lay a solid timber floor to my living room (asphalt floor) and dining room and hall (concrete screed floor). The house was built in 1950 so does have a dpc. Budget restricts me to using reclaimed flooring. I was originally thinking of parquet, though wanting to lay it in strip pattern rather than herringbone or other more complex pattern. As the total area is about 50m2 there would be rather a lot of work in scraping off the old asphalt to parquet. I do know that strip flooring can be fixed with adhesive, though I'd be very wary of doing that with long lengths of it. As narrow maple strip flooring 57-75mm wide is fairly readily available secondhand, I was wondering if that might be suitable, but cutting the lengths as appropriate so that the lengths used are quite flat. The flooring then would look like a random (short length) strip floor rather than regular parquet block floor.
There would be few tongue and groove end joints because of the cutting, so would this be a problem, though the long joints would all be T&G? Cutting end tongues and grooves, whilst simple on workshop machines, is not to easy using routers and jigs, so if possible I'd want to not do that.
Would this be a suitable method or are there any pitfalls that I should be aware of?
Thanks in advance.
Thanks in advance.
