Hi. Still confused on whether I want timber vs block build for a summer house.
Had the idea of doing the back wall in thermalite blocks and all other 3 walls in insulated timber... would this be a bad idea? Reason being is that the back wall of the old shed was totally rotten.
Also would this foundation hold up blocks well enough:
That's what I got so far. The footings all the way around range from 200-250mm depth to where you see; then on top of that will be a 200mm slab.
Also, is it OK to put an additional DPM on top of the 200mm slab after it is poured/set?
Also x2 I want to build a block perimeter, then have the timber sit on top of that, would I have to fold all the DPMs (external and internal) to go on top of the blocks and held down by the timber walls?
Feel free to point out any issues so I can rectify before it's too late lol
Thanks in advance.
Thanks in advance.
