Hopefully someone can clarify the below for me.
I'm from Ireland and here our building regs are pretty similar to the UK ones.
However in the Irish Part M regs you have to provide a 1200*750mm clear area parallel to the side or perpendicular to the front of any guest/visitable WC's for wheelchair transfer or if the entrance level is <45m2 then the door can be left open. As per pages 118-120 of our Part M 2010. Follow link to download our document here http://www.environ.ie/en/Publicatio...g/BuildingStandards/FileDownLoad,24773,en.pdf
In the UK Part M- all there appears to be is for the guest WC to have the requirement that a wheelchair can approach straight on or from oblique access. As per page 72 of your Part M.
Assuming its a new build apartment and not for social/affordable housing would I be right in saying so that as long as the frontal access requirement is met with that it is complies with regulations. i.e. no sideways transfer area is required.
Or if not can anyone provide a link to alternative guidelines/regulations stating otherwise.
