Hi all,
Firstly i would like to apologize if this question has been asked numerous times....
I have recently knocked a wall down that separated my kitchen and a long narrow cupboard, i have had all the appropriate conversations and a visit from building control and a subsequent visit from a structural engineer before the wall was knocked through.
I'm now at the stage where i need to sort the electrics, the demolished wall had one double socket on which i want to now relocate to the new kitchen wall, after speaking with building control this morning they are adamant that a certified electrician must do the work of relocating the socket as i am not qualified and they can then issue a minor works certificate.
After browsing this sites wiki on part P, it appears to imply that a kitchen is no longer a special area, therefore i can myself run the cables and install the socket and connect it up with no notification required.
As a new circuit is not required and i am simply rerouting the current wiring to a wall that is less than a metre away who is right? or am i misreading the wiki regs?
again sorry if the answer is obvious...
Regards
scott
Regards
scott
