Hi all,
New to the forum so Hi and thanks in advance for any advice! Hopefully I've posted in the right place.
I've got a 1930's property with a 9in red brick party wall. I had expected the soundproofing to be pretty good however I can hear my neighbours clearly and have strong cigarette & cooking smells seeping through.
As smells are getting through I think that's probably why the sound proofing is so bad, I've managed to spot where it's coming from - upstairs between the skirting and the floor in all rooms linked to the party wall. Downstairs the only area I have spotted is from a gap above the door frame of an under stairs cupboard (stairs run adjacent to party wall).
Has anyone ever heard of this before, party walls aren't supposed to have air gaps are they? Plaster work on the walls looks solid and flooring is level with no unusual creaking etc (I lived in a house with subsidence before with flooring problems!).
If I was to pull up floor boards and spray expending foam between the joists to seal the gaps would that work - is there anything more suitable I could do?
Many thanks,
Webbit
Many thanks,
Webbit
