- Joined
- 5 Jan 2016
- Messages
- 234
- Reaction score
- 8
- Country
Hi guys
Im picking my kitchen extension job back up, after loads of delays, builders pulling out etc im just starting myself and getting as far as i can.
I need to pass the drainage through the footings, as per usual using a bridge/lintel method with 100mm clearance.
My question is i have a new water supply that i will be layed in 115mm drainage pipe and labeled water, but needs to be 750mm minimum. So do i go deeper and go under footings, id rather avoid this. Or is it ok to just have it poured and surrounded? After all its a duct. Gas also needs to be layed from the same entry side
