D
Deleted member 18243
I'm about to start a large PAT testing project. I passed my C&G PAT testing exam a few weeks ago, but this job will be the first time I will have done PAT testing outside college.
I've had a look at some of the appliances I'll be testing and have the following questions... hope some of you can help:
1) There is a fridge, whose rating plate says 90 watts yet it has a 13a fuse in the plug. (I'm supposed to check for correct fuses in plugs and change any that are wrong.) Why does it have such a high fuse? Do I need to change it? Am I missing something on the rating plate? It is an average sized household fridge, but in an office kitchen. It has had a 13a fuse since new, ie it is a factory-fitted fuse.
2) Tests on electronic equipment. I know that IT equipment has to be "soft" tested, rather than use the 25a earth bond test and high-voltage insulation resistance test, but I'm unsure about whether I should soft-test equipment such as fridges, dishwashers and microwaves. These are not IT appliances, but they are modern, and have sophisticated electronics in them: timers, programmers etc, so do I soft-test these or do the full 25a earth bond test and 500v insulation resistance?
3) Do I PAT test so-called "Fixed" installations? We have hand dryers and water heaters that are screwed to walls and wired to fused spurs. From what I can deduce from the PAT testing code of practice I should test these items, but I've been told by various people that I shouldn't. What is the answer? Note that one of the water heaters is connected via a 13a plug, rather than a fused spur, and its neutral pin shows signs of overheating.
4) If I should PAT test the fixed water heaters and hand driers, referring to question 2, should I "soft" or "hard" test them, as they have electronic circuitry.
Phew! Bit of a minefield so far. Thanks.
