Patio Door
25 Jan 2019
We have a patio door which is lower on one side than the other
On the side where the height is ok I can access the roller at the bottom of the patio door
However, on the side where the height is lower I cannot readily access the roller at the bottom of the patio door
See photos of top and bottom of the patio door, the lower side shown
As you can see there is a PVC plastic cover, covering the side of the door. I expect th roller and height adjustment is below this pvc cover.
How do I get this pvc cover off and on again
A thin paint scraper type tool between the ' plastic cover' and where it meets the sliding door. It's only clipped in. Depending on the make it may have a to be clipped on between the fixed and sliding pane first upon refitting
Doors between the house and the street should be like front doors - sturdy and not let air in when it's cold outside the window. I would recommend installing French doors.
Firstly , holy thread revival!
secondly Sliding doors are external grade doors . A decent set will have many locking points and anti lift mechanisms. They are perfectly acceptable, not my personal choice but acceptable
No window or door should let air in when it's hot or cold ( unless open obviously lol ), what a bizarre statement .
