Patio drainage problem
20 Sep 2026
Hi all, first time on here. I am doing a self build and I've laid 20mm 900x 600 porcelain slabs all the way around my property but I want the path to continue into a 6m x 5m patio at the back.
The house is L shaped and I want to lay the patio between the 2 internal walls. How do I get a 1in 60 slope on both angles ? Do I have to install an Aco drain diagonally across the 6m x 5m ? Not keen on the look of this. I wanted to lay slabs all falling one direction but then the end of the patio would be 50/ 60mm lower than my path coming into it. Appreciate any advice. Thanks Paul
