Patio height advice
22 Oct 2011
Surrey
I think I've made a bit of an error on my patio height. As you can see from the pic the concrete base is 2 brick courses below the DPC and 1 below the aide brick - I was hoping to reuse some riven slabs but once bedded they'll come up to 1 and1/4 bricks below DPC and 1/4 brick below airbrick - will this be ok or should I look at thinner slabs/other suggestion.
View media item 76173
Sorry image is upside down
You need to leave 150mm between the ground and the dpc.
Can you dig out the concrete base, or install a Clark drain along the wall?
