    Dismiss Notice
Paving Bricks to Lawn
Discussion in 'In the Garden' started by Lofty93, 27 Feb 2019.
  1. Lofty93
    Lofty93
    25 Apr 2018
    6
    Thanks Received:
    Country:
    Hi all,
    My back garden is all paving bricks from the previous owner, but I want to remove all these and law down grass. What is the best route to achieve this? Underneath the paving bricks is sand, so not sure what I will need to do in order to make progress!
    Sorry for lack of information, never done this before so unsure what to do!
    Thanks for your time!
    Ryan
  2. Sponsored Links
  3. cwhaley
    cwhaley
    10 Jan 2017
    858
    Thanks Received:
    75
    Erewash, Derbys.
    Country:
    I did a very similar thing when extending my lawn and removing part of a patio laid onto sand. I removed the top layer of sand, dug in lots of new top soil (removing all large stones) mixed with fish, blood and bone (from Wilko), leveled, then topped up with soil, leveled again and then laid the rolls of turf.
    Not sure how much you know already but when laying the turf, it's important to butt the edges of each roll up to each other, walk on boards when flattening down and make sure it's well-watered for the first 6-8 weeks. Then when laid avoid walking on fit for 6-8 weeks again. You can check how well it is rooting to the ground after 3 or 4 weeks by gently pulling up a few of the corners.
    Grass is in effect a weed it is very resilient and grows quickly. Give it a good start with decent soil and the right nutrients and it will establish itself.
    • Thanks Thanks x 2
  4. sodthisforfun
    sodthisforfun
    17 Mar 2018
    4,791
    Thanks Received:
    396
    Country:
    I have just started this myself now. Last weekend we got rid of a huge shed and the thick concrete base, now working on the slabs and sand. There is no other way than flipping hard labour! Slabs and sand have to go, as does all the chunks of stones/hardcore often in and under the sand. Stones have a habit of making their way to the surface every winter, so the more you get rid of, the easier your life will be later and the nicer your lawn will look.
    Oh, and you'll need a skip. As we've just found out from our local dump, they only accept 6 bags of hardcore a month. (no wonder people fly-tip). It seems that most councils have become very strict on this.
    Top tip! I'd never had thought about fertilizer. Thanks.
  5. cwhaley
    cwhaley
    10 Jan 2017
    858
    Thanks Received:
    75
    Erewash, Derbys.
    Country:
    The sand doesn't have to completely go. I kept quite a bit in there has it helps with drainage.
  6. sodthisforfun
    sodthisforfun
    17 Mar 2018
    4,791
    Thanks Received:
    396
    Country:
    Yeah, I can't get all of it up, but as much as I can. I don't like sand because while it aids drainage in more clay soils, it also doesn't hold water or nutrients. I've not got clay, so am trying to get rid of as much as possible. :)
    • Like Like x 1
  7. cwhaley
    cwhaley
    10 Jan 2017
    858
    Thanks Received:
    75
    Erewash, Derbys.
    Country:
    I have a lot of clay in mine so I could get away with it, you are right about it not holding nutrients well.
    Guess it's just a question of how much you're prepared to work at it. This recent whether has been excellent for it as it's not too hot to work in and not too wet to make loads of mud.
    • Thanks Thanks x 1
  8. Nige F
    Nige F
    28 Jun 2005
    20,421
    Thanks Received:
    1,570
    Country:
    £4 a bag at ours ! and we're surrounded by countryside for the earth to go, plus farmers to take hardcore;)
    • Like Like x 1
  9. sodthisforfun
    sodthisforfun
    17 Mar 2018
    4,791
    Thanks Received:
    396
    Country:
    oooh, you lucky beggar!! :)
    £180 for a mini skip at ours.. Argh!
  10. Sponsored Links
  11. Lofty93
    Lofty93
    25 Apr 2018
    6
    Thanks Received:
    Country:
    Thank you, will give this a go!
  12. lostinthelight
    lostinthelight
    11 Feb 2016
    2,062
    Thanks Received:
    382
    monmouthshire
    Country:
    Always worth an ad on a local freecycle group, theres usually someone looking for hardcore and sand
    • Thanks Thanks x 1
  13. conny
    conny
    30 Jun 2008
    11,959
    Thanks Received:
    440
    Suffolk
    Country:
    Don't forget when you lay the turf to stagger the joints like brickwork.
    • Thanks Thanks x 1
  14. cwhaley
    cwhaley
    10 Jan 2017
    858
    Thanks Received:
    75
    Erewash, Derbys.
    Country:
    Good one forgot to mention that!
  15. sodthisforfun
    sodthisforfun
    17 Mar 2018
    4,791
    Thanks Received:
    396
    Country:
    Hey, does anyone know how long I have to wait until rolls of turf is around in the shops? Nearly done all the prep in the garden, and can't buy any other than online. Don't want to pay £40 delivery for the small amount I need.
    Cheers :)
  16. conny
    conny
    30 Jun 2008
    11,959
    Thanks Received:
    440
    Suffolk
    Country:
    Probably not for a few weeks when the weather should be more likely to stay warmer with little risk of frost spells.
    Grass won't grow if the temperature is below 8 degrees I think. If you managed to get some now and put it down it may well die off before taking root.
    • Like Like x 1
  17. sodthisforfun
    sodthisforfun
    17 Mar 2018
    4,791
    Thanks Received:
    396
    Country:
    Cheers Conny. I always thought that the best time to lay turf was from the Autumn to the Spring? But the lack of it in the DIY stores must means that I am alone in that thinking! :D
Loading...
Share This Page
