i have just had a builder looking to make a quote for a patio. they are flag stones, the patio will be going wall to wall at the bottom of the garden, so it wont be stuck in a patch of grass, he said he will put membrane down then a dry mix of sand and cement. why would you put membrane down when the whole area will be sealed.i mean if its done properly, no water is going to get through and if the substrate is compacted as it should be, surely no weeds are going to get through. i would appreciate your thoughts. i thought you only put membrane down when you were putting loose aggregate like bark or shingle.
