PC to TV help please.
  • Thread starter Thread starter EdwardCurrent
  • Start date Start date
E
EdwardCurrent
Hello All.
Could somebody help me out please.
I have a Samsung laptop with a 7 pin 's' type outlet, and a 15 pin VGA Type connector.
My Samsung tv has a marked 'PC in' a 15 pin VGA connector, as well as HDMI 's.
I know it sounds daft but if I get a VGA lead and connect it between them will my TV turn into my monitor :shock: :shock: ??? Or will I need software/drivers etc etc :x .
Thank you for any advice.
Regards
Ed.
Sorry if this first comment is too basic... you'll also need to switch the output on which is typically "Function-F7" which will cycle from laptop only to laptop+external to external only. You might find it problematical on laptop+external since the resolutions are unlikely to match; various things can go wrong like not filling the screen or resizing your desktop etc. Depending on the laptop, you may be able to set the output to a different resolution and keep the laptop display correct. If your TV is full HD, your laptop might not be able to drive it correctly.
