Two quick questions re installing a pearlstone tray onto marine ply.
(1) The manufacturer recommends a weak cement mix as a base. I've seen manufacturers of similar products state that floor tile adhesive can also be used. I happen to have floor tile adhesive but not some sand and cement....
So is floor tile adhesive recommended and if so, a flat or combed bed?
(2) When tiling down to a tray / bath, I have always grouted between the tile and the tray and then run a silicone bead over the top. Is this better than running a full silicone bead between the two and also over the top?
Cheers,
David[/u]
Cheers,
David[/u]
