- Joined
- 9 Mar 2023
- Messages
- 35
- Reaction score
- 1
- Country
Should be fine as long as I work out what I’m doing in advance.I'd do it DIY but then it's usually only certification requirements that stop me having a go at something.. How do you rate your competence, ability to climb a ladder and wield simple tools under the application of logic?
We are hoping to get a dormer loft conversion in around 1 years time. Wouldn’t that chimney or part of it go then?Perhaps you should consider repointing around the chimney where the gaps look large enough for water to penetrate before fixing the ceiling.
No idea, moved in around 1 year ago so cannot comment what’s happened in the past.Sometime in the past had a chimney breast in the spare room corner been removed?
You need to use a selfie on a long stick (eg a tile batten) from the spare room window to pic the flashing and flaunching of the chimney stack.
Also, stand back at ground level and take a wider pic of the rendered wall/stack - is that side the neighbour's side?
What needs doing specifically? Will need to get a professional in to do the lot.Christ on a crumpet that's worse than it looks!
Got a ladder?
Pronto.
Her side ? Have you been stalking, tell?OP,
4. If the neighbour has abandoned her side of the c/breast & stack then there might be a case for removing the total stack?
