Wondered if anyone could help with the following. I suspect I've got a broken CH motorised valve head, resulting in pump running 24/7.
With CH and HW off at timer, I'm still getting live to SL in boiler (neon1 on). If I unplug electrics to the CH motorised head the pump goes off (neon1 off). The system appears to operate fine with CH electrics unplugged, and I can happily control the HW supply.
To try and test things I swapped the CH and HW heads over, and likewise, their electric plugs. Upon enabling power the 3amp fuse in mains isolation switch blows!?
Swapped things back and replaced 3amp fuse. The CH valve is still controllable via the timer, ie, turning the room stat temp up and down, opens and closes the CH valve.
Does it sounds like a broken valve head? Any help/advice appreciated. Why would the fuse blow when placing 'suspect' broken motorised head on HW and not on CH?
Thanks,
Chris
Notes:
Boiler: Glow Work ultimate 70FF
Timer: Sunvic 207XL
Valves: BGMVSP-2 (555212)
Everything working just find until two evenings ago. No work has been undertaken recently and system is ~12 years old.
Thanks,
Chris
Notes:
Timer: Sunvic 207XL
