For the last year, we have had issues with our heating: We have an ideal standard boiler, nearly 15 yrs old, standard drayton lifestyle control timer, with a honeywell dgital thermostat in the hallway.
In Jan, the boiler would not fire up, although the "flame indicator" on the honeywell was displayed. The fan in the boiler was changed and this seemed to rectify the problem for a short while.
We did notice that the boiler would come on, but go off before the thermostat temp was reached. This is normally set at around 22-23 degrees, but as the weather was getting warmer, it was not an issue.
The control for the heating on the drayton is set to ON and the times & temps controlled by the honeywell.
The zones on the honeywell is timed for 0530 at 22 degrees, rising to 23 around 0730 with the lowest temp 19 degrees at 2345.
What has been happening is the mornings have been really cold on rising, with the boiler having been on at some point for a whlle but off when checked. According to the honeywell, the boiler should be on as the target temp is not reached. Increasing the temp on the honeywell made no difference. I tried switching off the boiler from the switch on the boiler, but it still did'nt fire up. It would normally be left in this state with the honeywell showing the target temp not reached and the "boiler on".
After a few hours, the boiler would then fire up!
As we have a service arrangenment with D&G, the following items were changed over the last month. First the pcb in the boiler - made no difference - still boiler starting then going off before stat reached target temp, the drayton timer changed - no difference, and finally the honeywell stat changed. This has made a difference, but now the radiator in the hallway does not get hot, subsequently causing the heating not to shut off as the target temp is not reached. Some rads downstairs are also now not getting hot, but upsatairs is fine.
The engineers that have attended do not seem to being doing any investigative work - is there something that they could be doing?
he did look at the valve and pump, but all was working ok then.
I'm getting really frustrated now as this has been going on far too long
Can anyone help please?
