Hello all, I have recently bourght a Peugeot 206 1.1 petrol on an 03 plate, the ignition has worn away where you press to open and close the doors remotly,on close inspection I can see where someone has tampered with the circuit board and there appears to be a very small rectangular shaped steel cover with a small rubber insert missing from one of the swicthes where the fob front push button lines up with it, would or could this affect the engine imobilizer to operate and stop the engine from starting? When it does start it runs fine hot or cold. What is the proccedure in getting a replacement key?
