Peugeot 208 gps fault on touch screen
18 Nov 2014
Warwickshire
any one had any problems with touchscreen on 208 mine shows gps error even thou I don't have gps build in and it starts changing radio stations over and cutting off my Bluetooth .
Going to Peugeot on Friday but they want £58 just for diagnostic even thou I took out the platinum extended warranty !
Is your car the same as mine i have a Peugeot 208 13 reg 1.4 VTI same error GPS I have no Nav but have noticed my Bluetooth doesn't work for a while after. Also only seems to happen when it's very cold out (weather). I also get a wet spot on the screen which makes the screen unusable.
You could try a reboot by disconnecting the battery or finding and pulling the fuse/s
Not sure if modern units are coded, this would be my only concern.
