Too good for 'em. They don’t deserve it.There's probably a reason that your meat had 'Not for the EU' on it...
I also like the beef short rib. Salt on top in the oven with tinfoil on the top - long and low drain off loverly liquid fat that has rendered out ( save for Sundays spuds) then foil off to get a crispy top.
How do you know that ?Beef short ribs have only become popular recently. They used to be sold as a joint called 'thin rib', but it wasn't well known and was usually turned into mince. More latterly it has been poshed up and called 'Jacob's ladder'. Some farmers used to call it ovenbuster because of the way it expanded when cooked.
Don't askHow do you know that ?
OMG here he goesI went through a phase about twenty years ago of researching and trying lots of different cuts of beef.
OMG here he goes
Yes we have all been through that phase in our teens.
I'm not AI-ing.
It was sort of a hobby for a while.
Yes we have all been through that phase in our teens.OMG
You said 20 years ago?How young do you think I am?
you said 20 years ago, OMG how old are you?Yes. I am lot older than 'teens' + 20 years.
Ok we get itOn my diagram, for instance, the joint which is usually called top rump is called thick flank. And the one labelled flank is where beef skirt comes from. Interestingly, the silverside is often split into two joints down a seam of gristle, and the smaller one is called the 'salmon cut'.
Oh FFS give it a rest will ya.Says my own sad old troll
Didn't make the grade...
But I guess you just don't like the truth!
