- Joined
- 27 Jan 2008
- Messages
- 29,949
- Reaction score
- 3,731
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Landline stopped working, unplugged it, and plugged into back of router instead, and it works again, but now for the phone to work, it needs power, so the router now needs a battery back-up. It uses a 12 volt 3 amp power supply, not measured power used, cordless phones use a lower voltage, 6.5 and 7.5 volt, so have looked at back-up using extra low voltage, and they do not seem to cover 36 watt until very expensive, so these
seem at £50 to be a good option, I do have a 150 watt, and 300 watt 12 (lead acid battery) to 230 volt inverters, but then got to look at how to recharge or maintain the battery, or I could run cables to the solar sockets, but not an easy route and cable sockets etc, likely cost more than the stand alone unit shown.
We had an old phone ready in case of a power cut, which was powered by the telephone socket, but it was designed to work with old post office 50 volt lines, so not sure it will still work without damage to router.
I can't be only one with this problem, so what have others done, rely on mobile phone, being also one option.
It is rare to have a power cut, and we could simply use the existing with extension lead for the odd time it happens, had some one knocked on my door and asked, I would have put the questions to them, but it was just a parcel through the door with a router same as old one.
seem at £50 to be a good option, I do have a 150 watt, and 300 watt 12 (lead acid battery) to 230 volt inverters, but then got to look at how to recharge or maintain the battery, or I could run cables to the solar sockets, but not an easy route and cable sockets etc, likely cost more than the stand alone unit shown.We had an old phone ready in case of a power cut, which was powered by the telephone socket, but it was designed to work with old post office 50 volt lines, so not sure it will still work without damage to router.
