pics from first job survry
18 Jan 2007
Nottinghamshire
This is the CU and associated pieces, the service head is 1 inch off the floor, cannot find Earth from service head, thou there is a small piece of bare 4mm wire tucked behind the mounting board!!
MEB is 4mm!!!!
This switch
no earth, and cables are fabric coated
Any comments :?:
Whats the green wire going into a small 'henley' block directly below the left of the meter? Is that a main earth or does it go to the CU(s)?
I think a bit of rewiring is in order :lol:
take more than 1 picture, no need for the tags
cant see if there is a wallace or not
It looks to me like it was originally a TN-S but the earth wire broke off or was removed at some point.
call the DNO and find out if they can provide an earth. If not then you will have to fit a rod and set up as a TT system.
Hi RF, yes that green wire has me some what confused! It just goes in there but that is it!!!!
Plugwash you better be taking the pee!!!
This house is surrounded by concrete, it is better fortified than colditz.
What about a nice bit of 16mm clamped to the armour :shock:
Note to self, contact DNO
Hi Breezer, will take more pics when I don't have to climb on top of mops and all.
Sorry about IMG tags!!!
Did you take any Ze/Zs readings? That would tell you if there was an attempt at an earth at least.
What do you bet that under the tape:
will be the remains of a sweated connection for that bare stranded main earth cable?
Hi Ban, knew you'd reply to that, no itention either. Have contacted YEDL they are coming to install an earth in 6 to 12 weeks!!!! :shock:
So unless I can find some sort of earth (first job test for Ze) then will be hammering in a temporary earth rod (as they suggested) can't believe it first real job and it contains just about everything!!!!!
Will have a real good look at incomer tomorrow and see if ther is the remains of one, is there anything I could do to reuse it on a temp basis BAZ?
CDO, no idea of meter age but it is also the same as mine!!
The house is 1930's so take your guess!!!
My house is 1920's!!!!
