The Titan TTB556DBT, about £80 (incl VAT), is 500W, the same as your present one - click hereI don't use it a huge amount and only spend out on expensive tools when they get a lot of use. Trouble is all the new cheaper ones are now only 350w
Maybe the problem I'm having?That's plenty. I suspect the 500W and 350 W motors are the same physical size, but if wound for 500W it can't handle the heat generated, hence the insulation fails.
Usually fairly easily with drills that size. Have you tried removing the belt, so you can ascertain whether the motor is making the chuck hard to turn, or the chuck etc. is making the motor hard to turn (or both!)?This may be moving to a more mechanical aspect but how tight should the chuck be when turning by hand, because it seems rather stiff. I've also taken the botom casing of the motor housing, and it is quite difficult to turn the motor fans. Should they be easy to turn or not?
Possibly - you could perhaps try some judicious lubrication. However, it's also possible that the motor is iffy and/or on its last legs and cannot cope when a significant load is applied to it.I was just taking the belts off after I last posted. With no load from the belts the motor starts and runs ok, and the chuck spins freely. Maybe this is not an electrical problem after all, but a pulley/belt one?
You're welcome, and I'm glad that things may be looking up. However, in view of the history of this saga, I'm not drawing any conclusionsHopefully it won't be another case of 'spoken too soon', but I've lubricated the pulleys and the drill now seems to work ok! Thanks for your posts John
