Hi all.
I have been having problems with gas pressure etc (see earlier posts).
I have had work done on my supply pipe by Transco.
I still have a few issues with pressure to my gas fire.
I have now been told that the pipe size installed by Transco could be lacking!!
They have run 22mm copper using approx 7.8m of pipe, 9 elbows and one formed bend from the new meter outside to the first T. This i'm told, with the fittings equates to 12.8m?
One opinion is that it should be at least 28mm over that distance as it is feeding a 31kw boiler, a 22.8kw range cooker and a 2kw fire.
I am fed up with differing opinions, is there somewhere on the web where i can get an answer, a definitive answer?
It amazes me how there can be so many different opinions, i thought that was the whole idea of an organisation like Corgi so everyone uses the same rules?
Cheers
Cheers
