Pipes in walls
10 Jan 2004
Hello There,
When running central heating pipes down solid (breeze block) partition walls how should i protect the pipes,
Thanks, Joseph
I hope you are not going to bury them in the walls. If you do, you may regret it. They could be put in trunking which is let into the walls, but you should be able to get to the pipes if you need to. You could run them on the surface and box them in, or just run them on the surface.
