- Joined
- 5 Jan 2005
- Messages
- 119
- Reaction score
- 0
- Country
Hi
I've just modded my CH by adding upstairs rads to the existing circuit.
Now I've had a couple of 'leakers' on 22mm Yorkshire fittings.
Obviously I've not heated them enough on the bottom of the fittings. I repaired these by replacing with end-feed fittings.
It's a different story practising on a work-bench as opposed to in between joists next to electrical cables.
Now... I have a 22mm tee which was dripping (5 drips every minute with pump running) on the branch. I've checked on it since and it has stopped. I've checked on it when it's cool and when hot/pump running.
If I was to leave it as "sealed" would it be likely to come back and haunt me once I've got my wooden floor down?
Do these remain "sealed" until sediment dislodges?
What should I do?
What should I do?
