PIR ceiling light for bathroom?
8 Jan 2009
Glengormley
Morning all - the ceiling light in my girlfriend's flat is one of those that switches on and off as you move around - it doesn't have a manual switch.
It's started flickering on and off, and is very annoying. I opened it and tried adjusting the on/off time with the little pot inside, but it didn't make a lot of difference - it's obviously faulty, so I just want to replace it.
Could anybody recommend one from Screwfix? I prefer using them as I can just pop in locally, but I can't seem to find one using their search facility :rolleyes:
Screwfix do not have many, and might not be bright enough for a bathroom:
and
(which some compain doe snot come on in the day if it is bright.
and not screwfix, but properly bright, and adjsustable.
but may be easier to use a shorter name.
'Ouch' (as I trip up)
Had PIRs in work bathroom.
The bathroom PIR had a very short on durtaion and was located near door.
If in bathrrom a bit too long, used to have to open cubical door in pitch darkness and wave arm out of door (with trousers around ankles) to get lights back on.
Or look a bit weird by waiting in cubical for next person to come into the pritch dark bathroom and activate PIR.
You could use a separate sensor which would allow a greater choice of light fitting.
Actually... it's a while since I was in her flat, and I've now remembered that it actually IS a separate sensor anyway :notworthy:
Here's a pic - easy to replace just the sensor do you think? I wouldn't know how to choose one...
*Actually... do you think this one would be suitable?
Yes likely perfect.
But mark and then photo the wires in the old unit before you pull out the wires.
Sfk
