- Joined
- 17 Oct 2007
- Messages
- 2
- Reaction score
- 0
- Country
Hi, brought a PIR activated wall lantern for the front door form B&Q to replace the existing non-PIR lantern. Works a treat! so brought two more to replace two non-PIR wall lanterns at the rear of my house. Wired up ok. Turn on from switch as (as stated in the leaflet) they both turn on after 5 seconds to begin their "1-2 min warm up period" after this they should both go off and only turn on during movement.
Howe ever only one goes off, the other stay on all the time. In addition the one that goes off does not come back on during any movement. The leaflet also states that if you switch the wall switch off and on within 1 second it will override the PIR and run all night. This does not work either, the one that was off stays off and the one that was on stays on! Any ideas?
