We are close to the end of our extension work and we are hoping to have 3 lights along our side passage that will be triggered by movement but also to be turned on (overridden) by 2 switches, one inside and one outside.
Unfortunately due to contract conditions I am not allowed to talk directly to the electrician subcontractor and the architect knows as little as me about electrics (not much).
I am aware that some lights that come with built in PIR sensors have a manual override functionality that is activated by switching the lights on and off. I presume the wiring for this setup would just be like any other lighting circuit. The PIR responding simply to the off-on sequence to turn it on and disable the timer.
I am also aware that if I used a regular lamp and a separate PIR that there is a wiring technique that will enable overriding.
However the light that I like, the Philips June PIR, a combined light and PIR is not advertised as having a manual override function.
http://www.philips.co.uk/c-p/162469316/mygarden-wall-light
My question is if there is any way to wire this to get the override facility?
Or is the only way to have override with a light that has override built in or having separate light and pir?
I appreciate there are quite a few questions about this already but I've struggled to find one answering this particular question.
Thanks for any help!
Tom
Tom
