I hope you can point me in the direction of a solution to the below.
1.5 mm twin and earth used to form circuit from 5A fuse on consumer board to 5A switched fused-spur which then feeds a PIR security light.
Everything works fine for about 2 or 3 days then the fused-spur fuse blows and also the 5A fuse of the board.
This is the only circuit fed by the 5A consumer unit
Its such a simple cicruit that I have checed and relayed twice that the only conclusion I can draw is that the PIR security light is faulty
Any help would be much appreciated
