I like them especially for 3 core swa in plastic boxes.
even used them as normal locknuts
Mainly on commercial switchgear though, where theres more room as seem easier to grip than the silly thin galv ones with about two threads
They do come with thread same size as standard locknuts
The grub screw dont stick out like that once screwed in and you dont need that always, same goes for the earth screw not always needed.
One side also has teeth so you can put it on and tighten with one pair of grips, or use the smooth side just like normal.
The only downside is where space is tight , there about 10mm thick
