As soon as it gets warm enough in 2008 to turn off the CH, we'll be getting a new boiler to replace the 10yr old one that was fitted to the house before it was extended & had a loft conversion.. ie it's old, inefficient, noisey and undersized.
Originally we were looking for just a boiler replacement (we know it'll be condensing) but I am also now thinking of zoning the house and also improving the way the conservatory rad is plumbed in (currently not very well IMHO). It would make sense to do this all at the same time, so I'm trying to work out what I want and whether it's realistic without re-fitting all the pipework (cost of which could outweigh the benefits).
At the moment, the conservatory rad is before the pump. I'm no plumber but this seems wrong to me. BTW... we normally have the valve on this rad OFF. The new boiler will have integral pump, so at last the flow to this rad would be pumped. I'd add either a zone valve or electrically driven rad valve so that the conservatory heating can be easily switched "on"/"off" from inside.
A quickly drawn sketch of the current system may help explain...
The boiler is in the conservatory (next to the conservatory rad) whereas the tank (unvented) and CH zone valve are in the bathroom probably 10-15 metres distance along the circulation pipes.
I would then get the 3 floors split, 1 zone each with local thermostatic control on each floor & TRVs on some of the individual rads. The pipework looks like it only needs minor changes to split ground & first floor.
My current thinking is relatively small changes to modify so it's like this...
So my first question is whether this arrangement of 3 CH zones effectively in parallel with the HW would work? Presumably the switching on the HW valve can be used to add HW prioritisation if needed ?
But my main quesiton is that this effectively gives 5 heating zones, where 1 zone (conservatory) is very close to the pump/boiler and the other 4 zones are some way away.
I would appreciate if anyone has any comments if this can be done achieved like this or whether the conserv. rad flow would have to come off at the same point as all the other zones.
Thanks... & happy new year to everyone !
