Can someone tell me what scratch and finishing types (best brands etc) of plaster I should buy from one of the sheds? I have a BQ , Homebase and Wickes on my doorstep if thats any help .
I bought some Wickes finishing plaster to repair some holes created in my bathroom when I removed some tiles. The job was pretty good and more than acceptable for behind tiles.
I am in awe of pro plasteres as I totally agree its a skill. However I know my limitations, the job in hand is a boarded up serving hatch.
If it's a plasterboard patch then you won't need bonding. Insert the piece of board so that it is just about a 2 mm lower the other plaster. Then apply scrim tape around the repair, then skim and blend in the patch with the existing surrounding plaster. It's not that easy to get right unless you've done it few times. Blend in with a wet paint brush before it starts to set. The trick is not to ruck up the scrim. However, if you don't use it it will crack.
If its plasterboard then use Board-Finish as the name suggests but if you are spreading onto board & existing plaster then use Multi-Finish.
If the joists are too deep into the hole then double board with 9.5mm.
