- Joined
- 30 May 2016
- Messages
- 51
- Reaction score
- 3
- Country
Hi guys.
So I finished a front bedroom a couple months back and all went well, plasterers were well happy with the job, I'm looking at doing some more rooms now but doubting my previous material choices.
I took the old ceiling down and put up 12.5mm plaster boards and took the walls back to brick, then dabbed 12.5mm boards on the walls as well as making sure to prevent drafts behind the boards.
Should I stick to this method again or is it proper practice to use insulated plasterboard on the cold walls? I'd ideally like to steer away as the loss of space and also the cost. I have 15 plaster boards to use up but if I must use insulated, I can use them on the internal walls.
Also I'm not sure what is the correct vapour layer I should be using on the ceiling before fitting boards.
One thing I do knowv for sure is I will use thermal for window reveals.
Sorry for the long post I have a habbit of over thinking.
