Plasterboard under chipboard flooring
12 Feb 2016
I am repairing a bathroom floor which has crumbling chipboard.
I've discovered that under the 22mm chipboard is some kind of plasterboard (18mm) with a small amount of fibreglass wool under that and then more chipboard underneath that (which is solid).
My initial plan was to cut back the crumbling chipboard to the middle of a joist and then to secure new chipboard to that with battens for support as necessary. However...now that I've found the second layer of chipboard underneath, I'm wondering if I can just fit new chipboard over the top without securing to anything. Would the plasterboard be strong enough to just lay new chipboard on top?
Also, the plasterboard is cracking in places. What would be suitable for repairing that? Self-levelling compound? Something else?
I'd appreciate any input and advice you might be able to offer.
Thanks!
Keep going down until you find sound material/background, clear everything to that level/grade and then build back up to sub floor level using battens and "wbp ply" leaving enough height/gap for your desired floor covering. WBP ply in a washroom is better than chipboard.
I have worked on conversions in the early 90's where we had plaster board on the floor then chipboard on top to comply with noise and fire regulations.
Andy
Andy
Yeah. Makes sense. Better soundproofing can be done now and will need to be if current flooring has failed.
Thanks for your replies.
The bottom layer of chipboard is solid so I was thinking to leave that and not try to attach anything to the joists beneath. So are you suggesting to get rid of the faulty/failing plasterboard? What would be a suitable replacement for fire/acoustic insulation?
And where would I put the battens?
Andy
A decade later, I just found myself in almost the same situation. I need to replace damaged 22mm moisture-resistant chipboard in my flat and discovered grey 18mm plasterboard underneath. I can't figure out which plasterboard to use to replace it. Oddly, the thinnest acoustic plasterboard I can see online is 19mm. Do I just use a normal grey one instead? Also, I planned to use SPAX 4.5 x 60mm screws to fix the chipboard to studs, but now, with the additional 18 mm layer, I am at a loss as to which one to use.
Warning old thread!
Huh?
So you need something about 18mm longer than a 4.5 x 60mm screw? How about a 4.5 x 80mm screw?
Warning old thread!
Yes, I noticed that, but since the topic is similar, I thought that I'd post here rather than create a new thread. I'm happy to do it if posting here is against the rules.
Knauf Tapered Edge Sound Panel - 12.5 x 1200 x 2400mm | Wickes.co.uk​
www.wickes.co.uk
www.wickes.co.uk
I've seen these - they are 12,5mm and I need 18mm to make the new subfloor level with the old one (18mm soundproof/fireproof plasterboard + 22mm moisture-resistant chipboard.
Thank you for the advice! I'm very new to this, and it took me a long time to research to find the screws I thought I'd be using before discovering another layer beneath the chipboard.
Do you mean these: https://www.screwfix.com/p/spax-tx-countersunk-self-drilling-wood-screws-4-5mm-x-80mm-100-pack/644va
