Hmmm. It may be what you think I 'need', but it's certainly not what I want!Ditch the whole plastering idea. uPVC cladding on battens is what you need.
Thanks. That's what I assumed you were implying, but I thought I ought to check!To reply to the ' which for the uneven wall ' question - it's dot dab for that.
Yes, it is (will be) a heated space. Only a small part of one of the walls is 'exposed to weather', and I've dealt with that essentially as you describe - constructing what is essentially an insulated stud wall inboard of the brick. The room is already sufficiently small that to put stud walls all round would not be very desirable (nor, I believe, necessary), but what I have done with the couple of bits of other walls that are 'cold' on the other side (but not exposed to weather) is to put (25mm) insulation between the battens. The other side of those 'cold' walls are within a large 'outside cupboard', and that other side (within the 'cupboard') will eventually have substantial insulation added (within the 'cupboard').Will this be a heated space? Are the single skins exposed to weather? If either of these are the case I'd put a stud wall inboard of the brick, insulate the gap and board the stud wall
Yes, that was the deciding issue for me. Whenever I touched one of the walls, bits of (130 year-old!) paint (if not also some brick dust!) fell off, so I went totally off the idea of hoping that plaster (and/or any other form of foam/adhesive) would stick to the walls very satisfactorily!I too would batten for aforementioned reasons of adhering to 130 year old paint.
That's exactly what I've now done.If using plasterboard, taper edge boards vertically means you don't have any non taper edges to finish (tapered boards are only thus on the long edges).
