Hi all, long time lurker here.
I'm intending to plasterboard my loftspace soon and from what i can gather it's a bit of a minefield.
Ultimately, what i want to achieve is a fairly clean mostly dust free loft space.
It's not going to be a 'room' so i'm not going through building control, and neither do i intend to have it plastered.
The reason i'd like to plasterboard it, is that i'll be having a homeserver sat up there and a switch and various other bits of technical guff that don't like too much dust floating around. I'll be up there fairly frequently sat in front of the server doing a bit of tweaking etc and i'd rather not have to change into my scruffs everytime i nip up there.
I've boarded out the floor already over some new insulation, but the next step is to insulate the loft space itself and then plasterboard.
From what i can gather, the foil stuff is the best way of insulating a loft, and then plasterboard straight over that, i plan on using the most lightweight plasterboard (9.5mm?). I will need to insulate to avoid extreme temperatures because of the equipment.
Is there anything else I need to take into consideration?
Thanks in a advance
Thanks in a advance
