Have completed the 'embedding ceremony' of low voltage halogen spot lights in both the kitchen and living room - never as easy as is made out.
The electrics were by far the easiest portion of this task!
Couldn't upheave the floorboards from above (they have been varnished and are used bare in the room above), so had to channel out the route for the cabling instead.
The plaster (and wooden slats above that)I drilled the large holes for the lighting also fragmented in parts which had to be patched (I used wood paste for the slats).
I used two in one plaster to patch up in the short term but I am looking to reskim the whole ceiling (not I but a pro!).
First of all the ceiling has a particular dodgy looking artex effect all over it which has chipped and flaked in certain area's. Can this be merely skimmed over and then repainted?
Secondly, when the skimming takes place will I have to take the lighting out or can I hitch them down a few mm and masking tape them up?
They look good but it's a hell of a task!
Many thanks.
Many thanks.
