    Dismiss Notice
Plastering behind radiators
Discussion in 'Plastering and Rendering' started by Bunce89, 28 Jan 2018.
  1. Bunce89
    Bunce89
    28 Jan 2018
    3
    Thanks Received:
    Country:
    I've had some new smaller radiators fitted leaving patches behind where the plasterer before we moved in didn't remove the radiators. As the patches are so small I was going to scrape off the woodchip wallpaper as it's falling off anyway and then skim the patches with thistle mutli-finish. My mate recommended easi fill as I haven't plastered before. Thoughts on what I should use?
  2. Sponsored Links
  3. foxhole
    foxhole
    14 Mar 2006
    16,918
    Thanks Received:
    1,923
    Kent
    Country:
    If you have no skills then something which sands easily would be best.
    Though to do it correctly then the rads should be loosened and swung down to allow full access.
  4. roy c
    roy c
    19 Jan 2008
    2,373
    Thanks Received:
    422
    Country:
    Or you could put reflecting foil behind to give a bit more heat out. You could probably get it from a plumbers merchant it is quite sturdy and you stick it on the wall with double backed sticky tape..
  5. Bunce89
    Bunce89
    28 Jan 2018
    3
    Thanks Received:
    Country:
    I'm going to take the radiators off but I've never plastered before. So is easifill the best option.
    The problem is that the wall that is now visible looks rubbish so putting the tin foil lining reflective stuff over would not be a good idea.
  6. alan333
    alan333
    5 Sep 2012
    1,298
    Thanks Received:
    252
    Glasgow
    Country:
    I haven't used easifill but have used fastset (which is normally used for fitting coving etc - they're probably both similar stuff). It leaves a soft finish so it can be sanded back to flat easily if you don't manage to get a great finish when applying. It also 'feathers down' well at edges, again, by sanding if necessary. Multi finish sets hard so you need to get it right before it hardens - much more difficult than plasterers make it look.
    To sand back use a flat sanding block with reduction paper, maybe 60 or 80 grit to start with, then maybe 160 grit to finish. And don't under estimate the amount of dust it'll produce.
  7. Bunce89
    Bunce89
    28 Jan 2018
    3
    Thanks Received:
    Country:
    Cheers @alan333 I'll give that a go. I don't doubt the amount of dust; I've learnt that after chasing plaster before and not putting a mask on
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
