Never seen a rsj packed out in bonding, they are nogged out by a chippie, then a peice of plaster board is fixed to it, or I nog the rsj myself.just on another note how many here have packed rsjs out with bonding b4 rendering over them?
i know that m8 i knew this was going to cause contreversy when i posted it but theres no going back now, ive been spreading for coming up to 7 years now i was working for this firm as an improver about 4 years ago to get some render under my belt and was following instructions which is why in my first post i said this is the way i was taught,No reflection on you Steve, as you know - and this is probably the first thing we 've not seen things from much the same view, so interested in the application .
I'd be interested to see any spec etc that shows this as a method ?
Roughcaster is correct, also sand and cement shrinks, gypsum expands.
With the gypsum being underneath, it can't expand, meanwhile the sand and cement is trying to shrink, both surfaces are on the move, which will lead to failure of the bond after time.
The two products are not compatable with one another, and never heard anyone doing this before, and been pushing shyte up walls for 27 years.
While the bonding may be dry and hard, the sand and cement when put on top of it will soak up the water, and so the bonding gets a good soak, to cut to the chase, bonding sets hard in, let's say a hour and half, sand and cement needs 24 hours or longer, so the bonding gets a good long soak which can break the crystal structure down and go soft, meanwhile the sand and cement is trying to cling to it. This whole method is a no no.even rc says hes put it on render
why would you put a bonding float coat onto render scratch ?why not follow through and put float coat of render on? when ever ive done a render scratch ive always followed through with a render float coatAs i said earlier, I've put bonding onto render/scratch many times,Sand and Cement,
Bonding is designed to go over THE TOP OF MANY BACKGROUNDS, sand and cement is not designed to go over gypsum plasters as you did. You fail to listen my friend. Years ago you would give a wall a scratch coat of bonding then top it with browning, however plasterers soon caught on that you could lay it on and rule it off, rub it up, then skim it, thus saving time by not using the browning over the top. You don't see much browning these days, as it's all hardwall.why would you put a bonding float coat onto render scratch ?why not follow through and put float coat of render on? when ever ive done a render scratch ive always followed through with a render float coa tAs i said earlier, I've put bonding onto render/scratch many times,Sand and Cement,
iv plasterd over renderd ofers bonding and if bonded over render
as long as your primer is ok what dif dos it make ither way you look at it theres gypsom on render or render over gypsom as lon as its on the wall and it stays there looks good and paints ok who give a F**K
some spreads i know say never use PVA out side for rendering **** i use it on rendering 99.9% of the time
lay off yer you do it your way and me and steve will do it our way OK
sorry double post trying to quote and ended up with 2 copies
nothing wrong with my ears m8 or my eyes for that matter its there for everyone to see you said bonding is not compatable with render full stop,i dont know why your bringing browning into the debate it wasent even mentioned, for the record i know everything about every undercoat and top coat you could mention, all the work u done back then with the bonding is all being chopped out cause its either black and crumbling with damp and we are now replacing it with fresh render you have created lots of work for us cheers for that much appreciatedBonding is designed to go over THE TOP OF MANY BACKGROUNDS, sand and cement is not designed to go over gypsum plasters as you did. You fail to listen my friend. Years ago you would give a wall a scratch coat of bonding then top it with browning, however plasterers soon caught on that you could lay it on and rule it off, rub it up, then skim it, thus saving time by not using the browning over the top. You don't see much browning these days, as it's all hardwall.why would you put a bonding float coat onto render scratch ?why not follow through and put float coat of render on? when ever ive done a render scratch ive always followed through with a render float coatAs i said earlier, I've put bonding onto render/scratch many times,Sand and Cement,
lol ok m8 you do that but you cant really take what they say as gospel i asked them about a bathroom once,and if they had there way sand and cement would never be used in a bathroom again as they said they recommenedtheredry lining system over render, also bondings used in applications that they would never recomend or haveeven thought of, like for instance packing out rsjs ask them about that and they will be clueless, ask them about mixing it with render as well as a lot do and see what they say, at the end of the day i know whats text book and the right way to do things but if an employer tells me to do it a certain way im going to do it,I sent an e-mail to British Gypsum on this subject, to get their official verdict. I'll tell you what they say.
You "have" to take what they (British Gypsum) about Steve, is onto a bonding coat scratch coat,,, (no difference), which in time will also probably go black and crumble with the damp, then throw off the cement render top coat.
If an employer tells you to do it this way, then that's up to him, but as Micilin said earlier,,where's the spec??? You will "never" see any spec for this method of ""rendering"". It's the wrong way to render. The arguments for this type "rendering"is (if you pardon the pun), full of holes.
http://www.francofinishes.co.uk/faq.asp[/QUOTE]that bonding coat has paint on one side water proofed render on the other theres not much chance of it getting damp, it a waste of time showing me links to stuff i already know i know what way its supposed to go round for petes sake.
that wall was 0ver 4 years ago now and i can bet you its still up there, and will be in years to come not like the walls of houses that got a good coating of bonding in every room in the house years ago,whole houses floated with bonding? including bathrooms? not for me m8 , came acoss one the other week in a shocking state it was , had a word 2day with a spread i respect and he said that hes not used bonding on its own but used a mixture of sand and cement plus bonding in the same situation,but lets get this right now, i know which way round plaster and s&c goes and if asked to do that again i would
