plastering narrow gaps
25 Oct 2008
Cheshire
Hello all,
Hoping you can help.
Some of the walls I'm plastering have small gaps between the door frame and the adjacent wall (of the order 2" wide).
I have a small trowel, but it is still about 3" wide, so in some cases has been insufficient. I've muddled along with this small trowel angled as best I can and used a filling knife to smoothe the rest! :eek:
Do anyone make trowels small enough or is there a better approach?
TIA
if you are unable to remove the facings theres trowels for all occassions here.
50mm gaps i would be tempted to remove the facings though.
Has anyone tried these or anything similar?
The margin trowels are very handy and easier to use. However, they are not usually s/s, so it is a good idea to keep them in an oily rag or clean and oil/spray with wd40 after use, because you use them only ocasionally.
You might want to rub them on an oilsstone or wet brick before use, just to give them a nicer edge.
